More than two months I can use my maya 2017 without any problem. But unfortunately from few days getting the following error messages on the same machine!!!
Error Messages:
1. Maya 2017 opening session:Failed to apply color management settings on file open: Failed to finalize the color transform..
2. Maya Output Window:
Graphic device does not support OpenGL Core Profile, fallback to OpenGL renderer.
VP2 Warning : Insufficient shader level capabilities. Vertex (4 vs 4), Geometry (0 vs 0) Pixel (4 vs 4)
VP2 Warning : Graphics hardware feature level insufficient to support renderer (2 vs 4)
Error: The GPU adaptor of the transform to finalize is null
Error: Failed to apply color management settings on file open: Failed to finalize the color transform..
Error: Failed to finalize the color transform.
API error detected in S:\Maya_2017_DI\src\Maya\src\Components\BifrostTmp\plugins\mayavis\BFPlugin.cpp at line 117
: (kFailure): Unexpected Internal Failure
Failed to register registerFragments.
Hi!
Are you on Windows 10 or did you recently install update 3 for Maya 2017?
A) Try re-install or update of Graphic Driver.
B) Try a reset of your preferences.
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Definitely reinstall your graphics driver. I ran a system update here on CentOS 7.3 which updated my desktop environment, themes, and kernel. I got that error right afterwards when launching Maya and a quick recompile of my driver did the trick.
Always looking to solve problems, if I'm helpful at all consider dropping a kudos!
