HELP!!! I keep pressing the F hotkey and suddenly my whole scene disappears!!! And i have things do tomorrow! I have tried restarting everything, I uninstalled and reinstalled maya and it's still not working.
Hi @Anonymous and welcome to the community!
The 'F' hotkey is usually used to focus on whatever is selected. If you select a mesh for example and press 'F' what happens?
You may also want to change your camera clipping by adding a few zeroes to the far clip plane.
Feel free to post more screenshots of your issue if this does not solve it!
Please hit the Accept as Solution button if my post fully solves your issue, or reply with additional details if the problem persists.
Kudos are greatly appreciated. Everyone likes a thumbs up!
All the best,
Sean Heasley
Technical Support Specialist
Autodesk Here to Help | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Installation and Licensing Forum | Maya Certified Hardware |
Hi @Anonymous just checking in, any changes?
All the best,
Sean Heasley
I have this same issue. I've completely deleted my pref file and it still happens. I've started a completely new scene created just a sphere pressed F. Everything disappears. I can't manually zoom in or out to see my object. Dragging a selection box across the screen doesn't reveal the pivot tool. Everything is just gone. The only way to get back to your model is to create a new camera and view through selected. If you press F in the new camera it breaks again and your forced to create another camera... or manually move the perspective camera back to 0,0,0. Extremely annoying and needs a fix. Renders 2018 unusable... like the other user, i'm going backwards to 2017... I love Arnold renderer. Too bad such a stupid bug ruins the software so badly. Such a commonly used script...
