extrude problem
extrude problem
After I extrude the polygon, something  strange happen. What do I miss?
I cant see any addition polygon from the viewport.
hamsterHamster
Which part is the confusing one?
Those white edges, most likely, are the UV seams, which you can check in the uvEditor. You can toggle their visibility in Display>Polygons>textureBorderEdges.
Or, if the problem is the uneven extrude, then that is because the faces are twisted and you are performing Local transform, try Global, or transform each face individually.
P.S. As this is purely modelling question, you could have posted in the Maya Modeling section.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Rufus_R
I think it's because you got multiple edges and faces on top of one another. If you highlight all your vertices use the merge vertices tool with a low threshold and then use the cleanup tool. And then extrude your faces that should fix it.
