Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Extrude faces go into each other from pushing too far?
2 REPLIES 2
Samsam2019
259 Views, 2 Replies
Hello all,
Is there a way that when I extrude the faces don't go into each other no matter how far I push them out?
Can faces be pulled out uniformly without bumping into each other like in my picture?
2 REPLIES 2
hamsterHamster
in reply to: Samsam2019
This is expected behavior. What you can do is to either:
1. Extrude continuous face loop (like left option in your screenshot), then delete unnecessary faces and fill the hole; still won't work on extreme extrusions for less than right angles;
2. (preferred) Extrude for how far needed, then do manual "untangling" by simply moving intersecting parts.
It is rather feasible that you would predict what program will do, than program predicts what's on your mind next.. at least, not for current state of AI. 😉
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
Samsam2019
in reply to: hamsterHamster
Thank you!
