Errors when Maya launch
Message 1 of 22
Hi Maya Team,
We are getting these errors in Maya when Maya 2018.2 is launching.
import mtoa
// Successfully imported python module 'mtoa'
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
Maya 2018 importing module pymel 1.0.10 (C:\Program Files\Autodesk\Maya2018\Python\lib\site-packages\pymel\__init__.py)
# Error: Register failed for arnoldAOVChildSelector #
// Successfully registered renderer 'arnold'
// Error: ...moduleInfo -d -mn ">Ó×´äîÚ{Q½|S…°ð»>Ã̈Üù¹ÎÏÑ×ôÔök}«³ú~­†ÇoâlîÞŒ¦CqãÕû7kWçÖyŸ¥à]²8ëÞ+GÒöWl×UëyY¬Šìí³µ÷¹Ë›|içÞä—TRùõÓì—¸ //
// Error: Line 1.152: Unterminated string. //
// Error: moduleInfo -d -mn "WLP¯ÈKaNDâ…pàY*›.9tÌ`©©¶ôÕCÎèÔr/"; //
// Error: Line 1.20: Unterminated string. //
// Error: line 1: No module definition file found //
// Error: moduleInfo -d -mn "Û"1YŸí;ÆKî[LüA¨—Ï?®DõÁ3ÞFæ®Ù}™G5s}Ù´î›(ÈþÁ2rKüZcÃl[˜¤óBmqi3zbT.Ò"; //
// Error: Line 1.22: Syntax error //
Do you know what could it be?
Thank you very much for your time.
Best Regards
Lukas
Replies (21)
Message 21 of 22
sean.heasley
Hi @Anonymous
Thanks that screenshot is fine, there's nothing outstanding on there so all your hardware should work fine with Maya.
That said, my second question in my above post was that you said the install went fine but did you properly perform a clean uninstall/reinstall of Maya?
Message 22 of 22
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
