Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
errors in Maya 8 pls give me solution...
2 REPLIES 2
379 Views, 2 Replies
1, In maya 8, In a polygon object if u select a face and when u apply extrude the extrude tool does'nt work
2, While modeling an object and tried to appy booleon on the object the whole model gets vanished
3, While creating an skeleton we are not able to select and move a particuler joint, if we do that the whole skeltion get affected.
expecting the solution for the above from u all...
2 REPLIES 2
1. Check that your extrude isn't created flat against your previous geometry.
2. Check what happens if you smooth both pieces.
3. Are you moving the root joint?
If Boolean isn't working try adding more divisions to your object. If u already have many divisions, make sure the vertices are all merged.
