error when selecting the lettice
I'm running an issue on Maya 2018.5 where when i create a lattice deformer the cage does not show up and i get this error when i select it on the outliner.
select -r ffd1Lattice ;
// Error: <function selCom at 0x7f29c5c04aa0>; //
// Error: Line 1.1: Syntax error //
is it a bug? or am i doing something wrong?
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Have you tried Resetting your Preferences to default? Sounds very similar to this issue, which was resolved by clearing the preferences folder 🙂
Let me know how that goes!
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Hope you're doing well 🙂 Just wanted to check in and see if you still needed help. If you were able to find a solution, please consider marking this case as solved so others can find the answer faster.
Thanks for being a part of our community!
Jordan Giboney
