Error opening XGen expression window
When I try to write an expression for an XGen description, Maya won't open the window to do so. This makes most of XGen unusable.
# Traceback (most recent call last):
#   File "D:\Program Files\Autodesk\Maya2020\plug-ins\xgen\scripts\xgenm\ui\widgets\xgExpressionUI.py", line 1990, in showEditor
#     self.xgExprEditor.applyExpr.connect(self.onXgExprEditorApplyExpr)
# AttributeError: 'builtin_function_or_method' object has no attribute 'connect'
mail
I have the same issue. Did you find out what it was?
mail
I actually got it working just now:D Updated to 2020.1 and Expression editor opens fine.
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Did you have a chance to try out @mail 's update suggestion? Any luck?
If you have found a solution, we would love to hear about it and mark this thread as solved. Clicking the "Accept Solution" button helps other forum members find the answer faster.
Thanks again for being a part of our community!
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
