Error occurred and cannot open paint skin weights tool settings.
Operation steps:
1. Select the mesh.
2. Click Paint Skin Weights Tool.
3. Click Tool Settings.
4. Error occurred, the error message is:
Error: file: /Applications/Autodesk/maya2018/Maya.app/Contents/scripts/others/artAttrSkinCallback.mel line 139: No object matches name: skinCluster353.matrix
I don't know what I did to somehow break the skin weight. And I cannot edit the skin weight anymore. What can I do now?
sean.heasley
Hi @Anonymous and welcome to the community!
Does this issue still occur if you try it on a new empty Maya scene?
If it's specific to one scene file, when you get a chance, can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so I can take a look at it?
Let me know if anything changes!
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Encountered same problem. Solved when I closed maya and opened again.
Opening a new file didn't change anything, I had to close the whole program and reopen.
When in doubt turn it off and then turn it back on again! 🙂
