Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Error message please help
4 REPLIES 4
bmcfa004
535 Views, 4 Replies
I went to save one of my projects and when I tried to reopen Maya I got this error If anyone knows what i did wrong and knows how to solve the help would be appreciated
loadPlugin renderSetup;
// renderSetup
# DHI.modules.maya.util : Preparing paths and loading DHI Plugins
# DHI.modules.maya.util : Running on Windows
Importing DHI external libraries
# DHI.modules.maya.util : Running Maya version 2017
# DHI.modules.maya.util : Fetching libraries from folder C:/Users/Bailey/Documents/Megascans Library/support/plugins/maya/6.9/MSLiveLink/DHI/lib/Windows/python2
['C:/Users/Bailey/Documents/maya/2023/scripts/site-packages', 'C:\\Program Files\\Autodesk\\Maya2023\\bin', 'C:\\Program Files\\Autodesk\\Maya2023\\plug-ins\\ATF\\scripts', 'C:\\Program Files\\Autodesk\\Bifrost\\Maya2023\\2.4.0.0\\bifrost\\scripts', 'C:\\Program Files\\Common Files\\Autodesk\\ApplicationPlugins\\bifrost\\Contents\\scripts', 'C:\\Program Files\\Autodesk\\Maya2023\\plug-ins\\MASH\\scripts', 'C:\\Program Files\\Autodesk\\MayaUSD\\Maya2023\\0.18.0\\mayausd\\MayaUSD\\plugin\\adsk\\scripts', 'C:\\Program Files\\Autodesk\\MayaUSD\\Maya2023\\0.18.0\\mayausd\\MayaUSD\\lib\\scripts', 'C:\\Users\\Bailey\\Documents\\Megascans Library\\support\\plugins\\maya\\6.9\\MSLiveLink', 'C:\\Program Files\\Autodesk\\Maya2023\\plug-ins\\fbx\\scripts', 'C:\\Program Files\\Autodesk\\Maya2023\\plug-ins\\camd\\scripts', 'C:\\Program Files\\Autodesk\\Arnold\\maya2023\\scripts', 'C:\\Program Files\\Allegorithmic\\Adobe Substance 3D for Maya\\2023\\scripts', 'C:\\Program Files\\Autodesk\\Maya2023\\plug-ins\\sweep\\scripts', 'C:\\Program Files\\Autodesk\\Bifrost\\Maya2023\\2.4.0.0\\vnn\\scripts', 'C:\\Program Files\\Autodesk\\Maya2023\\plug-ins\\xgen\\scripts', 'C:\\Program Files\\Autodesk\\Bifrost\\Maya2023\\2.4.0.0\\bifrost\\python\\site-packages', 'C:\\Program Files\\Autodesk\\MayaUSD\\Maya2023\\0.18.0\\mayausd\\MayaUSD\\lib\\python', 'C:\\Program Files\\Autodesk\\MayaUSD\\Maya2023\\0.18.0\\mayausd\\USD\\lib\\python', 'C:\\Program Files\\Autodesk\\Maya2023\\bin\\python39.zip', 'C:\\Program Files\\Autodesk\\Maya2023\\Python\\DLLs', 'C:\\Program Files\\Autodesk\\Maya2023\\Python\\lib', 'C:\\Program Files\\Autodesk\\Maya2023\\Python', 'C:\\Program Files\\Autodesk\\Maya2023\\Python\\lib\\site-packages', 'C:\\Program Files\\Autodesk\\Maya2023\\bin\\python39.zip\\lib-tk', 'C:/Users/Bailey/Documents/maya/2023/prefs/scripts', 'C:/Users/Bailey/Documents/maya/2023/scripts', 'C:/Users/Bailey/Documents/maya/scripts', '..', 'C:\\Users\\Bailey\\Documents\\Megascans Library\\support\\plugins\\maya\\6.9\\MSLiveLink\\Megascans\\RequestLibrary', '..', 'C:\\Users\\Bailey\\Documents\\Megascans Library\\support\\plugins\\maya\\6.9\\MSLiveLink\\DHI\\pose_wrangler', 'C:\\Users\\Bailey\\Documents\\Megascans Library\\support\\plugins\\maya\\6.9\\MSLiveLink\\DHI', 'C:/Users/Bailey/Documents/Megascans Library/support/plugins/maya/6.9/MSLiveLink/DHI/lib/Windows/python2']
# modules.maya.util : Running Maya version 2017
Loading plugin:
C:/Users/Bailey/Documents/Megascans Library/support/plugins/maya/6.9/MSLiveLink/DHI/plugins/Windows/2017/embeddedRL4.mll
Error loading plugin embeddedRL4
Loading plugin:
C:/Users/Bailey/Documents/Megascans Library/support/plugins/maya/6.9/MSLiveLink/DHI/plugins/Windows/2017/MayaUE4RBFPlugin2017.mll
Error loading plugin MayaUE4RBFPlugin2017
Loading plugin:
C:/Users/Bailey/Documents/Megascans Library/support/plugins/maya/6.9/MSLiveLink/DHI/plugins/Windows/2017/MayaUERBFPlugin.mll
Error loading plugin MayaUERBFPlugin
// Error: $gShelfTopLevel = $gShelfTopLevel;
// Error: Line 1.34: "$gShelfTopLevel" is an undeclared variable.
# Error: Error occurred during execution of MEL script
# # Line 1.34: "$gShelfTopLevel" is an undeclared variable.
# # Traceback (most recent call last):
# # File "<maya console>", line 1, in <module>
# # File "C:/Users/Bailey/Documents/Megascans Library/support/plugins/maya/6.9/MSLiveLink/userSetup.py", line 20, in initPlugin
# # Installer.createMSshelf()
# # File "C:\Users\Bailey\Documents\Megascans Library\support\plugins\maya\6.9\MSLiveLink\Megascans\Installer.py", line 27, in createMSshelf
# # shelftoplevel = mel.eval("$gShelfTopLevel = $gShelfTopLevel;")
# # RuntimeError: Error occurred during execution of MEL script
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found.
// Error: Failed to register Initialize Maya Modify menu. Cannot add Convert Primitives to Polygons menu item.
// Warning: file: C:\Users\Bailey\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\Bailey\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\Bailey\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\Bailey\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'.
// AbcExport v1.0 using Alembic 1.8.3 (built May 5 2022 22:34:38)
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: line 1: filePathEditor: Attribute 'aiStandIn.dso' and label 'Standin' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already.
import arnold
import mtoa
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
updateRenderOverride;
# SyntaxWarning: "is not" with a literal. Did you mean "!="?, at line 372, in "C:\Program Files\Autodesk\MayaUSD\Maya2023\0.18.0\mayausd\USD\lib\python\pxr\UsdUtils\updateSchemaWithSdrNode.py"
// Bifrost: Pre-loaded mayaUsdPlugin to access proper Maya USD libraries.
// Loading Bifrost version 2.4.0.0-202202121141-d3627ed
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
// Bifrost: Loading library: usd_pack, from: Autodesk.
// Bifrost: Loading library: BifrostUSDMayaTranslation, from: Autodesk.
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem".
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/muscle/cMuscle.mel line 505: menu: Object 'mainRigDeformationsMenu' not found.
// AbcImport v1.0 using Alembic 1.8.3 (built May 5 2022 22:34:38)
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/others/addSelectTypeItem.mel line 101: Cannot find procedure "updateSelectTypeItemState".
// Error: line 1: initializePlugin function failed (gpuCache)
// Error: file: C:/Program Files/Autodesk/Maya2023/plug-ins/MASH/scripts/MASHCreateUI.mel line 79: setParent: Object '' not found.
// Error: file: C:/Program Files/Autodesk/Maya2023/plug-ins/xgen/scripts/muAddShelfButton.mel line 125: Object '' not found.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# # file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# # File "C:\Program Files\Autodesk\Maya2023\plug-ins\sweep\scripts\sweepMenuItems.py", line 30, in add
# # mel.eval("ModCreateMenu " + g_mayaCreateMenuID) # MAYA_LOCATION/scripts/startup
// Error: line 1: Cannot find procedure "shaderBallRendererMenuUpdate".
updateRendererUI;
// Error: file: C:/Program Files/Autodesk/MayaUSD/Maya2023/0.18.0/mayausd/MayaUSD/plugin/adsk/scripts/mayaUsdMenu.mel line 57: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2023/2.4.0.0/bifrost/scripts/bifrostGraphMenu.mel line 351: menu: Object 'mainCreateMenu' not found.
// Error: line 1: Unknown workspace.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/performNewScene.mel line 59: Invalid argument:
4 REPLIES 4
east-eden
in reply to: bmcfa004
Hey,
Have you tried resetting your preferences? There's steps how to do that here: https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Cannot-fi...
Hopefully that fixes it for you 🙂
bmcfa004
Yes I tried that a few times
east-eden
I'm not sure then, the only other thing I would say is that the error seems to be conflicted between 2017 and 2023. So perhaps it's a versioning error? Are you trying to load something from 2017 in 2023 or the other way around?
bmcfa004
I don't think so, I can't even open a new project.
