Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Error 'function' object has no attribute 'isMapping' when call pymel.core in pmcmds.py
0 REPLIES 0
Message 1 of 1
hansyuan.yang
355 Views, 0 Replies
When I simply run the following code in Maya script panel:
import pymel.core as pm
s = pymel.core.sphere()
or
win_name = "MyTest"
if pm.window(win_name, q=1, ex=1):
    pm.deleteUI(win_name)
with pm.window(win_name):
    pm.showWindow()
I got error:
# Error: AttributeError: file C:\Program Files\Autodesk\Maya2020\Python\lib\site-packages\pymel\internal\pmcmds.py line 88: 'function' object has no attribute 'isMapping' #
Following the error, I found line 88 in pmcmds.py :
    if maintainDicts and util.isMapping(args):
        newargs = dict(args)
        argIterable = args.iteritems()
        isList = False
And if I print type(util), the result is function, not module? At the beginning of pmcmds.py is:
import pymel.util as util
So I think the for some reason, util's type is changed from module to function and result in the error. If I manually import pymel.util again with another variable and use it in pmcmds.py, Maya's code will run ok.
How can I fix this? I reinstall Maya completely but still not working. Thank you.
Labels (1)
0 REPLIES 0
