Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Error Code
7 REPLIES 7
Message 1 of 8
h_designer
1336 Views, 7 Replies
Error Code
Error: file: C:/Program Files/Autodesk/Maya 2017/scripts/others/checkHGControls.mel line 56: Object 'frameHierButton' not found.
7 REPLIES 7
Message 2 of 8
tony.su
in reply to: h_designer
How did you get this error? When you create your own script or use a script created by other guy?
Tony Su
Product Support
Message 3 of 8
h_designer
in reply to: tony.su
When i click on hypergraph hierarchy
Message 4 of 8
Megatoons
I have the same issue. NOT work the $30 dollar rent.
Message 5 of 8
Megatoons
in reply to: Megatoons
Ah...it's the old "delete the Maya.env" file trick. Ability to open restored.  NOPE still broken. Hypergraph is hosed. P*ssed about spending $30 again to support non-piracy, only to be punished. Oh well. Unfortunately, ups my consideration to Cinema 4D a bit since it integrates with AE.
Message 6 of 8
mspeer
Hi!
I suggest to re-install Maya and reset the preferences (you may try to reset preferences first, if it does not work do it after re-installation again)
Rename the folder prefs in folder 2017 to something like prefs_backup, or to reset everything, the folder 2017 to 2017_backup. Maya creates new folders. Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Message 7 of 8
h_designer
I install and reinstall but it's the same problem now i work with maya 2016.5 i think it's better for now
Message 8 of 8
1. Go to Preferences > Settings > Animation > Evaluation mode: DG
2. Now open Hypergraph, go to Options, turn off Heat map display
3. Then again go to Preferences > Settings > Animation > Evaluation mode: Parallel (if you need it)
The problen is that you can't use heat map options in hypergraph with parallel animation mode.
