Dynamics don't save
Dynamics don't save
introbuck
Dynamics don't save
introbuck
Hi!
The problem is when i do some changes in my scene with dynamic and then reopen that scene all my dynamics don't save changes i did before. For example when i started working on scene when mass for object was 5, then i changed it to 10, press save and when reopen scene it shows 10 but react like it is five. What can it be? It happens to all dytnamic parameters.
Abdulla-Qaladzay
Hi @introbuck
-after doing "save as" and "increment and save" then by using "save" all the changes will get save only in the last maya file.
-or you probuly opened an auto save after maya crash
-to figure that out where the file get save  after clicking on save check the script editor history the last line should be the full path of the maya file that you just saved
lynn_zhang
Hello @introbuck ,
Just checking to see if your problem has been solved. Did the response from @Abdulla-Qaladzay help answer your question? If yes, please click on the "ACCEPT SOLUTION" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
introbuck
yeah i kind of knew that but my problem is my dynamic starts react differently. For example the scene i opened have difference while playblast and again, because of dynamic reacts different. After i change mass from 0.5 (for example) to that same 0,5 it starts react just before i reopened scene. So i am curious why this might happen.
