Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Diffuse baking gives very strange results
8 REPLIES 8
Message 1 of 9
sofiane_09
1894 Views, 8 Replies
So i have my character UV mapped and i want to bake a Color ID map to texture it on Quixel suite.
As you can the mesh group is correctly UV mapped, but this i what i get when the texture is baked ( second image )
I've tried many settings. It doesn't work with the default bake settings anyway. I have even installed maya 2016 ( i'm on maya 2017 ) to try it on and it didn't work Does somebody knows how to fix this ?
Note that the baking doesn't work for very simple meshes such as a mere cube.
8 REPLIES 8
Message 2 of 9
mspeer
in reply to: sofiane_09
Hi!
You may check the normals.
For further help, please upload the scene-file.
Message 3 of 9
sofiane_09
in reply to: mspeer
Thank you for responding.
There were indeed a problem with normals, we can see this with smooth mode disabled.  (1st image)
I was able to fix this with set normal to faces (img 2)
However, i still have the same problem. the resulting baking failed. (img 3) The baking also doesn't work even if i do it with a simple freshly created cube. This is depressing.
Message 4 of 9
mspeer
Hi!
Please upload a scene-file (keep at least one of the meshes that fails when baking).
Message 5 of 9
sofiane_09
in reply to: mspeer
Oh yes i'm sorry, i've prepared the scene file but forgot to send it. Here
Message 6 of 9
mspeer
Hi!
It seems you forgot to tell Maya that the objects are not at the same position.
A) Transfer Maps -> Maya Common Output -> Transfer In "Object Space" (instead of "World Space"), or
B) move one object above the other (for example set both to Translate [0 0 0]).
Message 7 of 9
sofiane_09
in reply to: mspeer
Thank you very much, it works now !
Message 8 of 9
haiqalfitri345
in reply to: mspeer
Im also have the same problem and already tried your suggestion but it's not working. Im new in texturing.
Message 9 of 9
smsheard
in reply to: haiqalfitri345
I did the opposite of the advice above to fix this problem, IE I changed the setting from object space to world space. Hope this helps.
