I imported a project from Revit 2014 into Maya 2014 only to find that everything in the project now has a reflective glossiness to it. I've tried deleting the nodes in the Hypershade window, but I receive the error "Non-deletable node '#######' cannot be deleted".
The three nodes I'm trying to delete are "shaderGlow1", "particleCloud1", "lambert1".
I have searched the internet for help on how to unlock and delete locked nodes, deleting non-deletable nodes, etc. Unforunately none of the topics or scripts I have come across have done anything.
Although admittedly I know very little about programing or much about using code, all I know about code is to do when the instructions say.
Basically I just really need help on how to delete those three nodes, or if that is not possible, how do I remove the reflective glossy appearance those nodes are causing. Because I have even tried changing the values of those three nodes and its either reflective glossy are the entire project becomes pitch black.
Please let me know.
Thank you.
