Dash issues
Dash issues
Parmenides
Dash issues
Parmenides
Hello, I am having issues using the new 2018 Dash feature.
For example, I take a cube (1x1x1) duplicate it 9 times for a 10.  Then click on the translate X channel and alt-right click and put in l(10) the cubes are all aligned linearly next to each other as they should be.  But if I put in l(13) or l(16) I get the same result with no space between them which is incorrect.
If I put in l(20) they are 2 apart along the X which is correct.  It appears that it is rounding to the next whole number when moving them.  The command r(number) seems to be working correctly.
Nothing here to explain it : http://help.autodesk.com/view/MAYAUL/2018/ENU//?guid=GUID-94DA2210-6FF1-4993-8EB9-9A6D87562D35
mspeer
Hi!
I can reproduce this also with Maya 2017 update 4.
There is a workaround:
Enter "13.0" or "16.0".
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
Parmenides
Thanks. Yes, that works as a workaround. I wonder how that let that slip through?
