Ctrl+delete not working
ece_d
ece_d
it says this error message when I try to delete literally anything with ctrl delete: Error: line 1: Cannot find procedure "artAttrSkinPrevPaintMode"
and it was working perfectly fine until yesterday. I literally tried everything I could think of. it does the same thing in the versions 2024-2025-2026. I deleted prefs folder and changed the name to prefsOLD. It doesn't work. Please help. Thank you.
Christoph_Schaedl
Could you show us exaclty where this happens.
It does work fine here.
Does it work on a fresh cube?
https://linktr.ee/cg_oglu
ece_d
everything literally everything. a freshly added cube, something I already made, I even tried it on Maya tutorial mode!! it says the same thing when I try to delete something with ctrl+delete
stezzaboy
You have to select some faces, edges or verts first.?
