So I have been working with the Student version of Maya 2016. The instant I load anything but an empty scene, I get the following screen
Have of course looked what the script editor says:
file -f -new; optionVar -sv colorManagementColorPickerColorSpaceSelection "Rendering Space"; optionVar -iv colorManagementColorPickerColorMgtEnabled 1; // Warning: file: C:/Program Files/Autodesk/Maya2016/scripts/startup/rememberViewportSettings.mel line 43: Active stereo does not work with Aero enabled. Active stereo has been disabled. // optionVar -sv colorManagementColorPickerColorSpaceSelection "Rendering Space"; optionVar -iv colorManagementColorPickerColorMgtEnabled 1; // untitled // commandPort -securityWarning -name commandportDefault; // Warning: file: C:/Program Files/Autodesk/Maya2016/scripts/others/setWorkingDirectory.mel line 258: C:/Users/Kai/Documents/maya/projects/AnimDojo/scenes is not a valid directory. Using C:/Users/Kai/Documents/maya/projects/AnimDojo/ instead. // file -f -options "v=0;" -ignoreVersion -typ "mayaBinary" -o "C:/Users/XXX/Documents/maya/projects/AnimDojo/References.mb";addRecentFile("C:/Users/Kai/Documents/maya/projects/AnimDojo/References.mb", "mayaBinary"); closeAllNodeEditors; closeHypershade; requires "stereoCamera" "10.0"; updateRenderOverride; requires -nodeType "ilrOptionsNode" -nodeType "ilrUIOptionsNode" -nodeType "ilrBakeLayerManager" -nodeType "ilrBakeLayer" "Turtle" "2016.0.0"; updateRendererUI; +++++++ Turtle for Maya registered successfully ++++++ requires "xfrog4.0" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog4.0", was not found on MAYA_PLUG_IN_PATH. # requires "xfrog" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "xfrog", was not found on MAYA_PLUG_IN_PATH. # requires "tx_proxy2012x64" "8.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "tx_proxy2012x64", was not found on MAYA_PLUG_IN_PATH. # requires "syflex" "1.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "syflex", was not found on MAYA_PLUG_IN_PATH. # requires "stretchMesh2012_linux64" "1.6"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "stretchMesh2012_linux64", was not found on MAYA_PLUG_IN_PATH. # requires "splineDeform" "3.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "splineDeform", was not found on MAYA_PLUG_IN_PATH. # requires "shaveNode" "1.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "shaveNode", was not found on MAYA_PLUG_IN_PATH. # requires "saveNode" "8.5"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "saveNode", was not found on MAYA_PLUG_IN_PATH. # requires "realflow" "4.1.17"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "realflow", was not found on MAYA_PLUG_IN_PATH. # requires "pointOnPoly" "4.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "pointOnPoly", was not found on MAYA_PLUG_IN_PATH. # requires "opiumPipe2013x64" "1.0.4 build Wed May 07 16:40:03 CST 2014 (env variantion)"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "opiumPipe2013x64", was not found on MAYA_PLUG_IN_PATH. # requires "nwLightingTools" "2011_10_25_1608"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "nwLightingTools", was not found on MAYA_PLUG_IN_PATH. # requires "vrayformaya2008" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "vrayformaya2008", was not found on MAYA_PLUG_IN_PATH. # requires "mtorsubdiv" "1.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "mtorsubdiv", was not found on MAYA_PLUG_IN_PATH. # requires "mgear_rigSolvers" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "mgear_rigSolvers", was not found on MAYA_PLUG_IN_PATH. # requires "maxwell" "2.7.8"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "maxwell", was not found on MAYA_PLUG_IN_PATH. # requires "libCausticMap" "2.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libCausticMap", was not found on MAYA_PLUG_IN_PATH. # requires "speedo_py.py" "Unknown"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "speedo_py.py", was not found on MAYA_PLUG_IN_PATH. # requires "opiumPipe2012x64" "1.0.3 build 11/12/2013 4:37 PM (check model more)"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "opiumPipe2012x64", was not found on MAYA_PLUG_IN_PATH. # requires "holdoutView" "2008"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "holdoutView", was not found on MAYA_PLUG_IN_PATH. # requires "qualoth-2013-x64" "3.1-6"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "qualoth-2013-x64", was not found on MAYA_PLUG_IN_PATH. # requires "finalRender" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "finalRender", was not found on MAYA_PLUG_IN_PATH. # requires "fBounce" "2.3.7"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "fBounce", was not found on MAYA_PLUG_IN_PATH. # requires "elastikSolver" "0.990"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "elastikSolver", was not found on MAYA_PLUG_IN_PATH. # requires "dnTools" "1.6.8"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "dnTools", was not found on MAYA_PLUG_IN_PATH. # requires "fTrax" "0.4.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "fTrax", was not found on MAYA_PLUG_IN_PATH. # requires "dnRex" "1.79.10"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "dnRex", was not found on MAYA_PLUG_IN_PATH. # requires "pfOptions.py" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "pfOptions.py", was not found on MAYA_PLUG_IN_PATH. # requires "cTag.py" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "cTag.py", was not found on MAYA_PLUG_IN_PATH. # requires "benMatrixArrayOperator" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "benMatrixArrayOperator", was not found on MAYA_PLUG_IN_PATH. # requires "TurtleForMaya80" "4.0.0.6"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya80", was not found on MAYA_PLUG_IN_PATH. # requires "libSkinShader" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "libSkinShader", was not found on MAYA_PLUG_IN_PATH. # requires "rigOrient" "0.2.9"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rigOrient", was not found on MAYA_PLUG_IN_PATH. # requires "TurtleForMaya2009" "5.0.0.6"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya2009", was not found on MAYA_PLUG_IN_PATH. # requires "RosaCorrectShape.py" "Unknown"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "RosaCorrectShape.py", was not found on MAYA_PLUG_IN_PATH. # requires "pdiMaya2x" "2.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "pdiMaya2x", was not found on MAYA_PLUG_IN_PATH. # requires "ShaderPlugin" "11.01.2005"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ShaderPlugin", was not found on MAYA_PLUG_IN_PATH. # requires "ProgressiveMesh_Release" "0.6.5"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ProgressiveMesh_Release", was not found on MAYA_PLUG_IN_PATH. # requires "MayaMan_m4" "1.0.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "MayaMan_m4", was not found on MAYA_PLUG_IN_PATH. # requires "mbya" "2014"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "mbya", was not found on MAYA_PLUG_IN_PATH. # requires "rpmaya" "2.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rpmaya", was not found on MAYA_PLUG_IN_PATH. # requires "MayaMan" "2.0.15"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "MayaMan", was not found on MAYA_PLUG_IN_PATH. # requires "TurtleForMaya2008" "4.1.0.7"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "TurtleForMaya2008", was not found on MAYA_PLUG_IN_PATH. # requires "MatteNode" "4.5"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "MatteNode", was not found on MAYA_PLUG_IN_PATH. # requires "MatUtilityGLSL" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "MatUtilityGLSL", was not found on MAYA_PLUG_IN_PATH. # requires "LXFMLImport" "5.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "LXFMLImport", was not found on MAYA_PLUG_IN_PATH. # requires "HSVadjust2" "4.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "HSVadjust2", was not found on MAYA_PLUG_IN_PATH. # requires "mArny_maya" "2.27.24"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "mArny_maya", was not found on MAYA_PLUG_IN_PATH. # requires "DirectionalSculpt" " 1.050"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "DirectionalSculpt", was not found on MAYA_PLUG_IN_PATH. # requires "LEGO_EasyFlex" "7.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "LEGO_EasyFlex", was not found on MAYA_PLUG_IN_PATH. # requires "CgSlate" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CgSlate", was not found on MAYA_PLUG_IN_PATH. # requires "CGMWire" "2.8.6"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CGMWire", was not found on MAYA_PLUG_IN_PATH. # requires "CGMSubdConstrain" "2.8.6"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CGMSubdConstrain", was not found on MAYA_PLUG_IN_PATH. # requires "CGL_Rivet" "3"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CGL_Rivet", was not found on MAYA_PLUG_IN_PATH. # requires "correctiveShape85" "8.5"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "correctiveShape85", was not found on MAYA_PLUG_IN_PATH. # requires "rigConstraint" "1.0.21"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "rigConstraint", was not found on MAYA_PLUG_IN_PATH. # requires "PranaHair" "4.5"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "PranaHair", was not found on MAYA_PLUG_IN_PATH. # requires "AT_Scatter" "VersionTag_INSTALL_0-0-8298554"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "AT_Scatter", was not found on MAYA_PLUG_IN_PATH. # requires "fAssetMayaNode.py" "1.0.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "fAssetMayaNode.py", was not found on MAYA_PLUG_IN_PATH. # requires "ALK_TankNode.py" "1.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "ALK_TankNode.py", was not found on MAYA_PLUG_IN_PATH. # requires "DKPHair" "1.2.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "DKPHair", was not found on MAYA_PLUG_IN_PATH. # requires "randomGrid" "1.3"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "randomGrid", was not found on MAYA_PLUG_IN_PATH. # requires "am_metaballs" "3.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "am_metaballs", was not found on MAYA_PLUG_IN_PATH. # requires "RenderMan_for_Maya" "3.0.1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "RenderMan_for_Maya", was not found on MAYA_PLUG_IN_PATH. # requires "speedCamouflagedo_py.py" "Unknown"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "speedCamouflagedo_py.py", was not found on MAYA_PLUG_IN_PATH. # requires "afiLocatorNode" "0.0.1 13/11/09"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "afiLocatorNode", was not found on MAYA_PLUG_IN_PATH. # requires "3delight_for_maya2014" "7.0.12"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "3delight_for_maya2014", was not found on MAYA_PLUG_IN_PATH. # requires "surfaceConstraint" " 1.000"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "surfaceConstraint", was not found on MAYA_PLUG_IN_PATH. # requires "3delight_for_maya2012" "7.0.12"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "3delight_for_maya2012", was not found on MAYA_PLUG_IN_PATH. # requires "BI" ".0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "BI", was not found on MAYA_PLUG_IN_PATH. # requires "correctShape2013x64" "0.0.7 build Friday 12/5/12 2:15 AM"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "correctShape2013x64", was not found on MAYA_PLUG_IN_PATH. # requires "AT_MPView" "RC 1"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "AT_MPView", was not found on MAYA_PLUG_IN_PATH. # requires "CGMSubd" "2.8.6"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CGMSubd", was not found on MAYA_PLUG_IN_PATH. # requires "cartoonShader60" "Any"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "cartoonShader60", was not found on MAYA_PLUG_IN_PATH. # requires "CorrectiveShape70" "7.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "CorrectiveShape70", was not found on MAYA_PLUG_IN_PATH. # requires "nfxMaya400" "4.0.0"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "nfxMaya400", was not found on MAYA_PLUG_IN_PATH. # requires "3delight_for_maya2010" "2"; # Error: line 1: RuntimeError: file <maya console> line 1: Plug-in, "3delight_for_maya2010", was not found on MAYA_PLUG_IN_PATH. # optionVar -sv colorManagementColorPickerColorSpaceSelection "Rendering Space"; optionVar -iv colorManagementColorPickerColorMgtEnabled 1; # Error: file: C:/Users/XXX/Documents/maya/References/zbrush dog v3/dog_rig_v3.ma line 86: RuntimeError: file <maya console> line 1: Plug-in, "Mayatomr", was not found on MAYA_PLUG_IN_PATH. # // Warning: file: C:/Users/XXX/Documents/maya/References/zbrush dog v3/dog_rig_v3.ma line 1213353: Unrecognized node type 'mentalraySubdivApprox'; preserving node information during this session. // // Warning: file: C:/Users/XXX/Documents/maya/References/zbrush dog v3/dog_rig_v3.ma line 1213357: You must either select the affected nodes or specify them on the command line. // // Warning: file: C:/Users/XXX/Documents/maya/References/zbrush dog v3/dog_rig_v3.ma line 1213360: You must either select the affected nodes or specify them on the command line. // // Warning: file: C:/Users/XXX/Documents/maya/References/zbrush dog v3/dog_rig_v3.ma line 1213363: You must either select the affected nodes or specify them on the command line. // // Warning: file: C:/Users/XXX/Documents/maya/References/zbrush dog v3/dog_rig_v3.ma line 1213366: You must either select the affected nodes or specify them on the command line. // // Warning: file: C:/Users/XXX/Documents/maya/References/zbrush dog v3/dog_rig_v3.ma line 1230011: You must either select the affected nodes or specify them on the command line. // // Warning: line 2175: The default image may not be modified. Use the -i/image flag instead. // // Warning: line 0: Errors have occurred while reading this scene that may result in data loss.
Some of the errors may be specific to the current model, but I get it ALWAYS.
Most of the time, the mesh can't load the texture after the error, other times everything seems fine, but the export is damaged afterwards.
From what I could gather, I am missing like 500 plug-ins, but I never deleted anything (and I definitely tried to reinstall or repair Maya multiple times.
I am really tempted to simply get 2017 or something, in the hope that maybe everything will be in order then, but this is really getting on my nerves.
If anyone with more knowledge of the program could help me, I would really appreciate that!
What in the world is
opiumPipe2012x64
It looks like this scene is trying to load a whole bunch (a lot!!) of old plugins or you have a whole bunch of older version plugins set to autoload. Check your plugin manager.
Hi!
You say if you create a new scene, then save the scene and open it again then you'll get all these errors?
For me it looks like someone worked on a scene from Maya 2008 up to Maya 2014 while trying all 3rd party plug-ins available and now you try to load this scene on a different computer without all these plug-ins.
I checked my plug-in manager, literally every plug-in in existence is probably in my list and almost all of them on Auto-load.
Went over what I actually needed and the errors are gone for all but two scenes (which complain about mentalRay).
Thanks for the heads-up, I just saw that massive list of errors and didn't consider checking the plug-ins named in the errors at the end.
