Connection not made: 'file19.message' -> 'defaultTextureList1.textures[-1]'. Destination is locked.
942646156
942646156
Community Visitor
Community Visitor
Maya cannot create a map node
Please help me~~
darby_kim
Observer
Observer
I'm having a hard time with the same error 'maya 2022'
flymooncn
Observer
Observer
Try this:
import maya.cmds as cmds
# defaultTextureList1 -- the lock node.
cmds.lockNode('defaultTextureList1', l=False, lockUnpublished=False)
tianyisongN2U86
Observer
Observer
do you know to unlock or lock this 'defaulTextureList1' node not using script?
script works but i cannot find this node in maya.
creationasif
for temp solution you can run this in mel
lockNode -lock off -lu 0 defaultTextureList1;
For permanent solution you can ping me directly
ianxiang
It's default node of Maya. You can find it from here:
cmds.ls(defaultNodes=True)
Locking the default node can protect the node, but they will pollute Maya’s default environment.
If you open a wrong file, other files will have lock information when they resave.
# unlock all dfault nodes
[cmds.lockNode(i, l=False) for i in cmds.ls(defaultNodes=True)​]
yisyuanengine
Community Visitor
Community Visitor
