Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Compatibilidades varias versiones en un mismo ordenador
4 REPLIES 4
390 Views, 4 Replies
Good afternoon,
I would like to know if is possible to install different versions of Autodesk Maya on the same laptop.
I need to work on Autodesk Maya 2016 and Autodesk Maya 2017 on my academic project.
Tags (2)
4 REPLIES 4
mspeer
Hi!
- Yes.
in reply to: mspeer
Thank you, mspeer.
I need to know also, if it is possible to share objects between 2016 and 2017.
mspeer
Hi!
Maya scenes are not backwards compatible (you can't use newer features in older versions),
however loading simpler scenes like geometry should not be a problem, especially if exported as OBJ or FBX.
Keep i mind that using different Maya version during a project is not recommended.
in reply to: mspeer
I will keep it in my mind. Thanks for your support.
