Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Command line rendering renders over and over again
0 REPLIES 0
Message 1 of 1
287 Views, 0 Replies
I started a command line rendering (Maya 2020). I have one master layer and two render layers. The batch rendering within Maya works fine. Also the rendering from the command line works fine, however it never stops. After having rendered all layers it starts with the master layer again and so on. I googled that someone using Maya 2009 had the very same problem, and seemingly there was a workaround, but no one actually mentioned how this workaround looks like.
I use Redshift renderer as an external render engine. I tried both, to render as a still and to render as one frame of an animation.
I use the render -r file <filename> command without further options.
I would be glad for any advice. Thanks!
Labels (1)
0 REPLIES 0
Technology Administrators
