Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Color Management in Maya 2023 - using OCIO config 1.0
0 REPLIES 0
Message 1 of 1
sladkova.a
201 Views, 0 Replies
Hello, so we switched from Maya 2020 to Maya 2023. For whatever reason (using Open Pype in the company) we are sticking with ocio 1.0. We want to render in aces and view in sRGB. If I understand it correctly the 'Display' view transform is only available in OCIO 2.0. However the 'display' option appears to be active in the UI even when I am working in ocio 1.0 which is confusing because:
1. it says ACES in the 'display'
2. it shouldn't be active.
Could you clarify please? Should I ignore this? Is it correct as is? Thanks in advance
0 REPLIES 0
