Collecting names from "SHOW" dropdown menu
bandrzejewski
bandrzejewski
Dear ones!
Do any of you know how to collect the names of nodes that are displayed in the "SHOW" window dropped down in the viewport menu by  mel or pymel?
Thanx for help 🙂
hamsterHamster
Under the Select>AllByType you can see the type listing, and with EchoAllCommands you can get the mel analogue which can be injected into py.
SelectAllNURBSSurfaces;
select -r `listTransforms "-type nurbsSurface"`;
ls -selection -type "transform";
// Result: nurbsSphere1 nurbsSphere3 nurbsSphere2 nurbsSphere4 //
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
bandrzejewski
Thank you for your answer!
Maybe my English is not perfect, but I don't want to list objects of a given type from the scene, but just to list the types of objects that appear in the SHOW menu.
I can ask the nurbsCurves checkbox state by
modelEditor -q -nurbsCurves modelPanel4;
// Result: 1 //
but how to ask - which of the types in the list have status 1 to have Result e.g:
nurbsCurves, nCloths, motionTrails, greasePencils ...
...and so on
hamsterHamster
You might be looking for
modelEditor -q -nurbsSurfaces modelPanel4;
modelEditor -e -nurbsSurfaces false modelPanel4;
Look up into command reference for modelEditor, there's also Py version.
,,,_°(O__O)°_,,,
bandrzejewski
Nope, because it returns me the state of "nurbsSurfaces" checkbox , not the name of its flag.
Believe me, if it were so easy, I wouldn't ask 🙂 I am currently analyzing the core Maya scripts to find .mel which builds the viewport menus 🙂
Thanks anyway 🙂
hamsterHamster
well.. for my perspView
popupMenu -q -ia MainPane|viewPanes|modelPanel4|modelPanel4|menu26
// Result: menuItem3550 menuItem3551 showAllItem showNoneItem menuItem3552 showControllersItem showNurbsCurvesItem showNurbsSurfacesItem showNurbsCVsItem showNurbsHullsItem showPolymeshesItem showSubdivSurfacesItem showPlanesItem showLightsItem showCamerasItem showImagePlaneItem showJointsItem showIkHandlesItem showDeformersItem showDynamicsItem showParticleInstancersItem showFluidsItem showHairSystemsItem showFolliclesItem showNClothsItem showNParticlesItem showNRigidsItem showDynamicConstraintsItem showLocatorsItem showDimensionsItem showPivotsItem showHandlesItem showTexturesItem showStrokesItem showMotionTrailsItem showPluginShapesItem showClipGhostsItem showGreasePencilsItem showPluginObjectsItem_gpuCacheDisplayFilter menuItem3553 showManipulatorsItem showGridItem showHUDItem showHoldOutsItem showSelectionItem menuItem3554 menuItem3555 //
 Turn on echo all commands to find the panel you need. Command reference is your friend there.
,,,_°(O__O)°_,,,
bandrzejewski
oh ... and it looks promising 🙂
import maya.cmds as cmds
list = cmds.popupMenu("MainPane|viewPanes|modelPanel1|menu14",q=1,ia=1) # name of window
for obj in list:
    if 'show' in obj:
        if 'All' in obj or 'None' in obj:pass
        else:print obj[4].lower()+obj[5:-4]
 It works FINE !!!!
GREAT!!!
