Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Cleanup Menu Is Not Appearing
6 REPLIES 6
daniel.e.morowitz
1308 Views, 6 Replies
Recently, I tried pulling a model into ZBrush but it told me that the model had faces with more than 4 sides. I know how to fix that, so I went back into Maya, went to Mesh> Cleanup and... nothing happened. A menu never showed up and continues not to show up. Is the Cleanup function broken? I curently have Maya 2016 installed with Service Pack 6.
6 REPLIES 6
The image below is from Maya 2016 SP6. Maybe try resetting your preferences?
Nope. Resetting didn't work
Are you using just one monitor? (Just trying to make sure the dialog box is not hidden offscreen somewhere.)
Yeah, I only have one screen
Alright, to test your idea, I connected a second screen and the cleanup text box appeared on the second screen. Its as if my computer is acting like there is a second screen, even when there isn't
Did you move the dialog box back to your original monitor? It should stay there if you do.
Technology Administrators
