Announcements
Checker select?
Checker select?
Hi
I individually clicked all faces highlighted in below image but how can I automatically checker select those faces?
mspeer
Hi!
You can't do this in Maya.
There is something like every nth edge, but this works only for edges.
hamsterHamster
Not one click solution, and still, you will need Maya Bonus tools to be able doing this, like @mspeer mentioned:
1. Select edges #1 and #3 -> BonusTools>Modeling>SelectEveryNthEdge;
2. Convert selection Ctrl+RMB>ToFaces>ToFaces;
3. Ctrl+Shift deselect upper face ring.
Note.. you can add edge loop to the side faces and select that. And, if you are up for modeling a gear, then there is Create>PolygonPrimitives>Gear.
,,,_°(O__O)°_,,,
Maya2019.1 @ Windows10 & GeForce GTX1080Ti
If the post was helpful, click the
 ACCEPT SOLUTION  button, so others might find it much more easily.
