Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Check if Maya UI is enabled or disabled (setAttr)
0 REPLIES 0
Message 1 of 1
238 Views, 0 Replies
Hello!
I try to find a solution for this since hours. In the Maya UI attributes can be changed using sliders. (e.g. A fluid container -> Density Scale, Diffusion, ...)
When I change a slider, the setAttr() function is callesd. Ok, now let's assume that a slider or a text field are dissabled. That means I can not change the value. (see image)
Nevertheless, it is still possible to use setAttr(). Is there a way to chck if a "element" us enabled or disabled?
Wold be great to get some help!!
Tags (2)
0 REPLIES 0
Technology Administrators
