Channel Box toolbar Icons gone in Maya 2016 extension 2
The Channerl Box toolbar Icons are gone in Maya 2016 extension 2
the functionallity is still shown in the online docs (middle of page):
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Maya/fil...
but they disappeared in 2016 extension 2! Tthe slider setting was super useful and I use it all the time. Please bring it back, or is it a bug?
sibleon
I believe it's a bug. The settings are still available in the channel box menu under Edit > Settings > Invisible Manips etc.
When I try to use this, it yields an error:
// Error: file: C:/Program Files/Autodesk/Maya2016.5/scripts/startup/initChannelBox.mel line 151: Object 'cbManipsButton' not found.
I hope you didn't remove these options intentionally as they are super useful.
Unrar, copy and replace the attached file to this directory and restart Maya.
Program Files\Autodesk\Maya2016.5\scripts\startup\
If you want to fix it manually for another version of Maya:
1. Go to Program Files\Autodesk\Maya2016.5\scripts\startup\ and open "initChannelBox.mel" with Wordpad.
2. Find this line:
global proc checkManipButton ( int $state )
3.
symbolButton cbManipsButton;
Add this line above the line we found in Step 2:
So it should look like this:
4. Save file and restart Maya.
