Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Change green wire display thickness
5 REPLIES 5
introbuck
4967 Views, 5 Replies
Screenshot_1.pngHello, how can i make thoose wire lines become more thick? I found how to change color, but don't know how to make them look like they have to be in Viewport 2.0 mode. Now i use Legact viewport and would change that display setting
5 REPLIES 5
introbuck
in reply to: introbuck
you may notice  some displays fine (simple line) but half another is stroke-like and that's what i want to change - make them all display like normal
mspeer
Hi!
For Legacy Viewport you have to use in Viewport menu:
Shading -> Smooth Wireframe
However there is one mode where it does not work correct and this is
Smooth Mesh Preview with Subdivision Method "OpenSubdiv...".
So either disable Smooth Mesh Preview or set the Subdivision Method to "Maya...".
donnaDRF3H
Window - Settings/ Preferences
Display
Change the line width under View
steve.davy
in reply to: donnaDRF3H
nsegre549JG
This is the answer.  Thank you.
