Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Cant get Maya to open (2023 Windows)
10 REPLIES 10
Message 1 of 11
lukemoore3
2042 Views, 10 Replies
everytime i open up Maya this is what i get .
loadPlugin renderSetup;
// renderSetup
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found.
// Error: Failed to register Initialize Maya Modify menu. Cannot add Convert Primitives to Polygons menu item.
// Warning: file: C:\Users\luke\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\luke\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\luke\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\luke\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\luke\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 12: filePathEditor: Attribute 'substanceNode.substanceFile' is invalid or is not designated 'usedAsFilename'.
// AbcExport v1.0 using Alembic 1.8.3 (built Feb 16 2022 14:36:32)
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: line 1: filePathEditor: Attribute 'aiStandIn.dso' and label 'Standin' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already.
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already.
import arnold
import mtoa
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
updateRenderOverride;
# # C:\Program Files\Autodesk\MayaUSD\Maya2023\0.16.0\mayausd\USD\lib\python\pxr\UsdUtils\updateSchemaWithSdrNode.py:372: SyntaxWarning: "is not" with a literal. Did you mean "!="?
if sdrIdentifier is not "":
// Bifrost: Pre-loaded mayaUsdPlugin to access proper Maya USD libraries.
// Loading Bifrost version 2.4.0.0-202202121141-d3627ed
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
// Bifrost: Loading library: usd_pack, from: Autodesk.
// Bifrost: Loading library: BifrostUSDMayaTranslation, from: Autodesk.
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem".
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/muscle/cMuscle.mel line 505: menu: Object 'mainRigDeformationsMenu' not found.
// AbcImport v1.0 using Alembic 1.8.3 (built Feb 16 2022 14:36:32)
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/others/addSelectTypeItem.mel line 101: Cannot find procedure "updateSelectTypeItemState".
// Error: line 1: initializePlugin function failed (gpuCache)
// Error: Failed to get time control widget.
// Error: file: C:/Program Files/Autodesk/Maya2023/plug-ins/MASH/scripts/MASHCreateUI.mel line 79: setParent: Object '' not found.
// Error: file: C:/Program Files/Autodesk/Maya2023/plug-ins/xgen/scripts/muAddShelfButton.mel line 125: Object '' not found.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# Error: Error occurred during execution of MEL script
# # file: C:/Program Files/Autodesk/Maya2023/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# # Traceback (most recent call last):
# # File "<maya console>", line 1, in <module>
# # File "C:\Program Files\Autodesk\Maya2023\plug-ins\sweep\scripts\sweepMenuItems.py", line 30, in add
# # mel.eval("ModCreateMenu " + g_mayaCreateMenuID) # MAYA_LOCATION/scripts/startup
# # RuntimeError: Error occurred during execution of MEL script
// Error: line 1: Cannot find procedure "shaderBallRendererMenuUpdate".
updateRendererUI;
// Error: file: C:/Program Files/Autodesk/MayaUSD/Maya2023/0.16.0/mayausd/MayaUSD/plugin/adsk/scripts/mayaUsdMenu.mel line 57: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/Bifrost/Maya2023/2.4.0.0/bifrost/scripts/bifrostGraphMenu.mel line 351: menu: Object 'mainCreateMenu' not found.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/fur/FurPluginCreateUI.mel line 17885: menu: Object '' not found.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/bulletInitUI.mel line 322: Object '' not found.
// Error: toolButton -q -ann $gNonSacredToolWidget;
// Error: Line 1.41: "$gNonSacredToolWidget" is an undeclared variable.
// Error: line 1: Unknown workspace.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/others/projectViewer.mel line 152: Unknown workspace.
// Error: file: C:/Program Files/Autodesk/Maya2023/scripts/startup/performNewScene.mel line 59: Invalid argument:
Start of trace: (command window: line 1).
MTsetToggleMenuItem (command window: line 1).
10 REPLIES 10
Message 2 of 11
ben.corke
in reply to: lukemoore3
  1. Hey did you manage to fix this issue I’m having the exact same problem and can’t seem to fix it.
  2. thank you
Message 3 of 11
tony.su
in reply to: ben.corke
Try change Maya fold to Maya_back in C:\Users\<user name>\Documents\maya.
Tony Su
Product Support
Message 4 of 11
selim9N3VW
Hello same here, console errors at startup, the maya opens with no menus at all!
this is a fresh legit install, do you have any solutions?
// Error: Unable to execute igInitialize.mel.
// Error: Unable to execute xgen.mel.
// Warning: file: C:\Users\apyloc2\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\apyloc2\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\apyloc2\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'.
// Warning: file: C:\Users\apyloc2\Documents\maya\2023\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'.
// AbcExport v1.0 using Alembic 1.8.3 (built Feb 16 2022 14:36:32) ETC ...
Message 5 of 11
JOHNHASTHIS
in reply to: tony.su
literally go in and change the folder name to Maya_back in C:\Users\<user name>\Documents\maya to the Maya_back and it fixed it.
Tags (1)
Message 6 of 11
not working for me. other solutions???
Message 7 of 11
conor_hillBF3NP
after a long week of struggling.....i have reached the other side.....thank you Brother.
Message 8 of 11
marco_acostaRHSFY
TY!!! it worked
Message 9 of 11
kies0015
This worked for me, thank you so much
Message 10 of 11
aalanisallens
Worked for me too, they should really make it more compatible with onedrive...
Message 11 of 11
2021111948LWLD
Thank you so much!! This worked for me. I was literally uninstalling and reinstalling Maya a couple of times already.
