Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Cannot find procedure "MTsetToggleMenuItem"
0 REPLIES 0
Message 1 of 1
christian.bayerDZ3B6
188 Views, 0 Replies
installed Maya 2023 on MacOS and PowerBookPro.
Installation runs through.
Error while starting Maya.
Tried reinstall several times.
Also renamed prefs folder.
Always the same error.
Any advice?
Best regards,
Christian
loadPlugin renderSetup;
// renderSetup
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem".
// Error: file: /Applications/Autodesk/maya2023/Maya.app/Contents/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found.
// Error: Failed to register Initialize Maya Modify menu. Cannot add Convert Primitives to Polygons menu item.
// Warning: file: /Users/christianprof.dr.bayer/Library/Preferences/Autodesk/maya/2023/prefs/filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: /Users/christianprof.dr.bayer/Library/Preferences/Autodesk/maya/2023/prefs/filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'.
// Warning: file: /Users/christianprof.dr.bayer/Library/Preferences/Autodesk/maya/2023/prefs/filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'.
// Warning: file: /Users/christianprof.dr.bayer/Library/Preferences/Autodesk/maya/2023/prefs/filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'.
// AbcExport v1.0 using Alembic 1.8.3 (built Aug 3 2022 14:41:43)
// Error: line 86: Cannot find procedure "buildDefaultHotBoxMenu".
// Error: file: /Applications/Autodesk/maya2023/plug-ins/MASH/scripts/MASHCreateUI.mel line 79: setParent: Object '' not found.
// Error: file: /Applications/Autodesk/maya2023/plug-ins/xgen/scripts/muAddShelfButton.mel line 125: Object '' not found.
// AbcImport v1.0 using Alembic 1.8.3 (built Aug 3 2022 14:41:43)
// Error: file: /Applications/Autodesk/maya2023/Maya.app/Contents/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# Error: Error occurred during execution of MEL script
# # file: /Applications/Autodesk/maya2023/Maya.app/Contents/scripts/startup/ModCreateMenu.mel line 1181: menu: Object 'mainCreateMenu' not found.
# # Traceback (most recent call last):
# # File "<maya console>", line 1, in <module>
# # File "/Applications/Autodesk/maya2023/plug-ins/sweep/scripts/sweepMenuItems.py", line 30, in add
# # mel.eval("ModCreateMenu " + g_mayaCreateMenuID) # MAYA_LOCATION/scripts/startup
# # RuntimeError: Error occurred during execution of MEL script
// Error: toolButton -q -ann $gNonSacredToolWidget;
// Error: Line 1.41: "$gNonSacredToolWidget" is an undeclared variable.
0 REPLIES 0
