Announcements
Cannot Connect 2 Objects
Cannot Connect 2 Objects with vertices because both have different vertices Look Black Wired First Object White Wired 2ndLook Black Wired First Object White Wired 2ndfaces edges
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thanks for posting! Can you share your scene file for us to look at? It would also be helpful to know the steps you are taking (what tools you are using in Maya) and what your end goal is 🙂
Thank you for your time! I look forward to hearing from you and getting this resolved for you.
Jordan Giboney
Technical Solutions Engineer | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
i want to generate vertex point in another object
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Thank you for your reply. Could you elaborate a bit more on what you are trying to achieve?
If you are working with two separate objects, and are looking to combine them with a single vert, here is the process to do so:
  1. Select both objects
  2. Combine the two objects together by navigating to Mesh > Combine
  3. Maya will now see both objects as one single mesh
  4. Select the vertices you want to combine
  5. Navigate to Edit Mesh > Merge to combine these verts
If this is not what you are trying to achieve, can you please post the scene file? 🙂
Thank you for your time, and I look forward to your reply.
Jordan Giboney
Thanks Fixed This Issue In 2016 Maya Extention 2 I Know 2012 Version Is Very Different From 2016 Ex2
jordan.giboney
Autodesk Support
Autodesk Support
Hi @Anonymous
Glad to hear that the issue has been resolved! 🙂 If you wouldn't mind selecting a solution for this thread, that would be great! Doing so will help other users find this answer more quickly if they run into the same problem.
Thanks and have a great day!
Jordan Giboney
