Can't unhide objects
Message 1 of 9
I'm trying to unhide objects but unfortunately maya won't let me do it.
I already tried Display > Show > All and set the attribute visibility to Checked.
Did i missed something?
Replies (8)
Message 2 of 9
ys.kuzi
did you try shift+h ?
Message 3 of 9
mspeer
Hi!
Maybe the mesh (shape) below the transform node is hidden.
Open the tree at pCylinder1 ...
Message 4 of 9
yup, doesn't work.
Message 5 of 9
I think shape was missing in my transform. (i don't know why).
@mspeer wrote:
Hi!
Message 6 of 9
faline.custodio.da.silva
@Anonymous
It appears that the shape you're looking for is either missing or hidden in the outliner. You could use the Node Editor to see what's missing.
Have you check the visibility on pCylinderShape1?
Faline Custodio Da Silva
Message 7 of 9
@faline.custodio.da.silva wrote:
@Anonymous
@faline.custodio.da.silva it works! cheers.
Message 8 of 9
HEY I'M HAVING COMPLICATIONS WITH A HIDDEN OBJECT,
I HID IT USING THE H KEY TEN SAVED MY PROJECT ONLY TO RETURN AND NOTICE THAT I CANT UN-HIDE IT,
IS THERE ANY WAY OF SOLVING THIS PROBLEM?
please and thank you.
Message 9 of 9
ojimenezaWN946
Community Visitor
Community Visitor
There`s a fix, in the outliner select all items and then press Shift +H, the problem came when you have a loot of meshes in the scene probably the outliner doest show all of them so need to verify in the trees of each geometry if theres something hiden, select them and press shift H again,  thats so anoying but thats a parcial solution. I losted a lot of work for that inconvenience, and isolate button doesnt work well because doesnt allow to create meshes in that mode, so....in conclusion dont press alt+H in a complex scene.
