Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't see textures in Maya
2 REPLIES 2
778 Views, 2 Replies
Hello, I am applied a texture to a model I made in Maya but I can't see the texture. I tried the 6 key but nothing happens. Do I need to activate something maybe?  Can anybody suggets what can i do?
I'm using Maya 2011 by the way
Anna
Moderator : moved here from the french forum
2 REPLIES 2
sean.heasley
Hi @Anonymous  and welcome to the community!
A quick test you can try is deleting your settings/preferences.
What happens if you apply a new material and tweak the color value? Can you see a change in the viewport?
Also, what kind of image are you using for your texture?
sean.heasley
in reply to: sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
