Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't save preferences
1 REPLY 1
chrismferguson
152 Views, 1 Reply
Maya isn't saving preferences, not sure what to do. I've tried reinstalling many times. Any help would be appreciated.
file -f -new;
// untitled //
commandPort -securityWarning -name commandportDefault;
onSetCurrentLayout "General";
// Loading Bifrost version 2.3.1.0-202110140143-ddfa15b
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: mpm, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Bifrost: Loading library: graphs, from: Autodesk.
[WinError 2] The system cannot find the file specified: 'C:/Users/chris/Documents/xgen/'
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 8: filePathEditor: Cannot write file 'C:/Users/chris/Documents/maya/2022/prefs/filePathEditorRegistryPrefs.mel'. Please check the file. //
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 9: filePathEditor: Cannot write file 'C:/Users/chris/Documents/maya/2022/prefs/filePathEditorRegistryPrefs.mel'. Please check the file. //
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 10: filePathEditor: Cannot write file 'C:/Users/chris/Documents/maya/2022/prefs/filePathEditorRegistryPrefs.mel'. Please check the file. //
// Warning: file: C:\Users\chris\Documents\maya\2022\prefs\filePathEditorRegistryPrefs.mel line 11: filePathEditor: Cannot write file 'C:/Users/chris/Documents/maya/2022/prefs/filePathEditorRegistryPrefs.mel'. Please check the file. //
// AbcExport v1.0 using Alembic 1.7.5 (built Nov 30 2020 18:40:46)
evalDeferred "shaderBallRendererMenuUpdate";
// Error: line 1: filePathEditor: Cannot write file 'C:/Users/chris/Documents/maya/2022/prefs/filePathEditorRegistryPrefs.mel'. Please check the file. //
import arnold
import mtoa
import mtoa.cmds.registerArnoldRenderer;mtoa.cmds.registerArnoldRenderer.registerArnoldRenderer()
updateRenderOverride;
// AbcImport v1.0 using Alembic 1.7.5 (built Nov 30 2020 18:40:46)
updateRendererUI;
saveShelf Polygons "C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_Polygons";
// Error: line 1: Can't open the file: C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_Polygons //
saveShelf Bifrost "C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_Bifrost";
// Error: line 1: Can't open the file: C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_Bifrost //
saveShelf XGen "C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_XGen";
// Error: line 1: Can't open the file: C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_XGen //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/syncGlobalOptVars.mel line 72: Failed to save C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_Polygons.mel. Check write permission //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/syncGlobalOptVars.mel line 72: Failed to save C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_Bifrost.mel. Check write permission //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/syncGlobalOptVars.mel line 72: Failed to save C:/Users/chris/Documents/maya/2022/prefs/shelves/shelf_XGen.mel. Check write permission //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/preferencesWnd.mel line 101: Save of "C:/Users/chris/Documents/maya/2022/prefs/userPrefs.mel" failed //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/preferencesWnd.mel line 101: Save of "C:/Users/chris/Documents/maya/2022/prefs/windowPrefs.mel" failed //
// Saving runtime commands to : C:/Users/chris/Documents/maya/2022/prefs/userRunTimeCommands.mel
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/preferencesWnd.mel line 101: Save of "C:/Users/chris/Documents/maya/2022/prefs/userNamedCommands.mel" failed //
// Warning: line 1: Save of "C:/Users/chris/Documents/maya/2022/prefs/pluginPrefs.mel" failed //
// Warning: file: C:/Program Files/Autodesk/Maya2022/scripts/startup/preferencesWnd.mel line 101: Not all preferences were saved. See Script Editor for details. //
1 REPLY 1
maya sucks, can't get it to work. Unbelievable. Back to blender i guess
