Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't open Maya 2022!
8 REPLIES 8
Message 1 of 9
jmollot
6682 Views, 8 Replies
I install it, and then I start it and it gives me a host of errors. I haven't been able to install and open a new version of Maya since 2019 on my Mac! This time I at least got it to install - I actually can't even open the installer for Maya 2020. I think this has something to do with how I uninstalled it one time maybe? If anyone has any answers that would be great. I have an education license so I can't actually contact Autodesk. These are the errors I get for 2022 (I tried resetting the preferences and re-installing it):
// Error: line 1: Cannot find procedure "MTsetToggleMenuItem". //
// Error: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/muscle/cMuscle.mel line 505: menu: Object 'mainRigDeformationsMenu' not found. //
// AbcExport v1.0 using Alembic 1.7.5 (built May 20 2020 20:04:37)
// AbcImport v1.0 using Alembic 1.7.5 (built May 20 2020 20:04:37)
// Error: line 1: Cannot find procedure "rebuildShowMenu". //
// Error: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 40: initializePlugin function failed (sceneAssembly) //
// Error: Unable to execute igInitialize.mel. //
// Error: Unable to execute xgen.mel. //
// Error: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/startup/ModObjectsMenu.mel line 56: setParent: Object 'mainModifyMenu' not found. //
// Error: Failed to register Initialize Maya Modify menu. Cannot add Convert Primitives to Polygons menu item. //
// Warning: file: /Users/jacobmollot/Library/Preferences/Autodesk/maya/2022/prefs/filePathEditorRegistryPrefs.mel line 4: filePathEditor: Attribute 'aiImage.filename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: /Users/jacobmollot/Library/Preferences/Autodesk/maya/2022/prefs/filePathEditorRegistryPrefs.mel line 5: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: /Users/jacobmollot/Library/Preferences/Autodesk/maya/2022/prefs/filePathEditorRegistryPrefs.mel line 6: filePathEditor: Attribute 'aiStandIn.dso' is invalid or is not designated 'usedAsFilename'. //
// Warning: file: /Users/jacobmollot/Library/Preferences/Autodesk/maya/2022/prefs/filePathEditorRegistryPrefs.mel line 7: filePathEditor: Attribute 'aiVolume.filename' is invalid or is not designated 'usedAsFilename'. //
// Error: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 40: initializePlugin function failed (Type) //
evalDeferred "shaderBallRendererMenuUpdate";
// Warning: line 1: filePathEditor: Attribute 'aiStandIn.dso' and label 'Standin' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiVolume.filename' and label 'VDB' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiImage.filename' and label 'Image' have been saved already. //
// Warning: line 1: filePathEditor: Attribute 'aiPhotometricLight.aiFilename' and label 'IES' have been saved already. //
import arnold
// Error: Failed to import python module 'arnold' //
// Error: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 40: initializePlugin function failed (mtoa) //
// Loading Bifrost version 2.2.1.0-202102081428-b33b49f
// Bifrost: Loading library: Amino, from: Autodesk.
// Bifrost: Loading library: AminoMayaTranslation, from: Autodesk.
// Bifrost: Loading library: bif, from: Autodesk.
// Bifrost: Loading library: bifrostObjectMayaTranslations, from: Autodesk.
// Bifrost: Loading library: geometries, from: Autodesk.
// Bifrost: Loading library: fluids, from: Autodesk.
// Bifrost: Loading library: particles, from: Autodesk.
// Bifrost: Loading library: file, from: Autodesk.
// Bifrost: Loading library: midgard, from: Autodesk.
// Bifrost: Loading library: modeling, from: Autodesk.
// Bifrost: Loading library: nucleus, from: Autodesk.
// Bifrost: Loading library: simulation, from: Autodesk.
// Bifrost: Loading library: riv_types, from: Autodesk.
// Bifrost: Loading library: riv, from: Autodesk.
// Bifrost: Loading library: scatter_pack, from: Autodesk.
// Warning: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 40: Failed to run file: /Applications/Autodesk/maya2022/Maya.app/Contents/MacOS/plug-ins/ufeSupport.py //
// Error: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/startup/autoLoadPlugin.mel line 40: (ufeSupport) //
import arnold
// Error: line 86: Cannot find procedure "buildDefaultHotBoxMenu". //
// Error: file: /Applications/Autodesk/maya2022/plug-ins/xgen/scripts/xgenUI.mel line 451: Cannot find procedure "MakeXGenHUD". //
// Error: file: /Applications/Autodesk/bifrost/maya2022/2.2.1.0/bifrost/scripts/mw_loadui.mel line 120: setParent: Object '' not found. //
// Error: file: /Applications/Autodesk/maya2022/plug-ins/MASH/scripts/MASHCreateUI.mel line 102: setParent: Object '' not found. //
// Error: file: /Applications/Autodesk/bifrost/maya2022/2.2.1.0/bifrost/scripts/bifrostGraphMenu.mel line 327: menu: Object 'mainCreateMenu' not found. //
// Error: file: /Applications/Autodesk/maya2022/Maya.app/Contents/scripts/startup/ModCreateMenu.mel line 1182: menu: Object 'mainCreateMenu' not found. //
// Error: file: /Applications/Autodesk/mayausd/maya2022/0.8.0_202102180129-2f83c8f/mayausd/MayaUSD/plugin/adsk/scripts/mayaUsdMenu.mel line 55: menu: Object 'mainCreateMenu' not found. //
updateRendererUI;
8 REPLIES 8
Message 2 of 9
patrick.schock
in reply to: jmollot
Hello @jmollot,
I would recommend to uninstall Maya 2022, following the clean-uninstall steps from this article: Perform a Clean Uninstall.
Please make sure that your popup blockers are deactivated and download the 2 installation files for Maya 2022 from your Autodesk Account. Verify that 2 files are downloaded and install Maya 2022 again and test if it works.
Looking forward to your reply, if you had success!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Message 3 of 9
jmollot
in reply to: patrick.schock
Unfortunately this did not work for me. I may have left some files that I couldn't find when attempting to uninstall, but I'm exceedingly cautious because I don't want to go in terminal and delete files and potentially cause a greater issue (like happened to me before). Here's all the errors this time:
import arnold
updateRendererUI;
Message 4 of 9
hannesdelbeke
same error here with 2022, other mayas work fine. 2018 19 and 20
Message 5 of 9
here is an article on 2020 from the same error
cause: corrupt install / default settings
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-fil...
Message 6 of 9
jonathan_khao
I had a module in Maya's base module folder (~/Documents/Maya/modules) that was trying to use python 2 code and caused the same error. Moving it in a versioned folder (~/Documents/Maya/modules/2020) prevented 2022 from loading it and I was able to launch Maya 2022 for a few days.
However, the error just reappeared.... I tried to remove any custom modules from loading in 2022 but it doesn't work anymore...
Message 7 of 9
i fixed mine.
the issue was caused by:
i defined MAYA_MODULE_PATH in the sys env variables.
this resulted in python code being auto loaded in all versions of maya.
python 2 code was loaded in the new maya 2022 python 3 environment
i imported some standard python 2 modules (ex. httplib)
these same modules were also included and imported by some default maya modules, but in python 3
this resulted in a clash between py2 and p3 in maya 2022
Message 8 of 9
Thanks for the info.
I checked for :
- all system variables
- used the error console to print `getenv(MAYA_MODULE_PATH)`  and removed ALL modules in these folders
- made sure no userSetup.py or .mel added anything to the path
But still got the error...
I uninstalled Maya2022 multiple times, rebooted but still got the error...
Turns out that I had a SECOND Maya2022 install nested in Maya2022's folder... Not sure why it happened since I generally use the default parameters and the installer should warn me it's already there... Anyways, I uninstalled one version with the windows unsinstaller, manually removed the second one, and it finally worked after re-installing...
Message 9 of 9
svo1
Does Maya 2022 work on MACBOOK PRO 2013? I have the software and made sure I didn't make any duplicates, but it's strange that it doesn't pop up still. Any suggestions? (Also saved on a hard drive WD to be specific). Tried running every command I got from you guys, my professor, the contact support, nothing.
