Can't move selected UV shell
So I have the folowing problem. When in UV Editor I seleckt a shell, somehow all shells get selected and i can't move or rotate a single shell.
Just to elaborate a bit more on the topic, I used to be able to move every single shell seperatly and than my baby banged on the keybord and this happaned. I am very new to Maya so I have no idea if it is some option or something that happaned when she was smaking the keybord.
Ok, so the problem is someting with Maya, it's the same issue across all files that i open i can't seem to select single vertex ir edge or face and move it. Everithing gets selected and moves together. Can anyone pls help ?
RFlannery1
I have no idea.  If I were having that problem, I would try resetting my preferences: https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
damaggio
U have enabled soft selection , toggle B key.
I fixed it. Try to see if your soft selection is on. That was the problem with me.
