Hi all,
Just installed Maya 2016 extension 2 SP2 and i can't load the plugin Direct Connect in the plug in manager.
There is a solution on the forum:
But I can't figure out how to re-install Direct Connect.
Thanks.
Solved by info. Go to Solution.
Solved by cornelh. Go to Solution.
Since Maya 2016 Ext 2, Maya has been using a different licensing method and thus Direct Connect is unable to run, as it uses the old FlexLM system.
So Direct Connect actually only works up to Maya 2016 Ext1 SP6. It does install in Maya 2016 Ext2 yet it doesn't work!! That is why we have moved to the ATF which is still not as robust as the Direct Connect. The Maya Development Team is diligently trying to make ATF able to handle the same import and export capabilities as Direct Connect.
To be able to use Direct Connect you will need the 2016 Maya Ext 1 SP6 as a workaround while we try and get ATF at the same level as DC.. huge apologies and we definitely appreciate your patience with this issue.
Thank you.
Here's Direct Connect for Maya 2017:
https://apps.autodesk.com/MAYA/en/Detail/Index?id=2891749639718941708&os=Win64&appLang=en
