Can't launch Windows 10 Maya, Output Window shows Warnings
21915791
Observer Observer
21915791
Observer
Observer
Hi!
Worked on Maya a few days ago everything was fine. Today faced a problem with launching Maya.
The Maya workspace wasn't open at all, only the outputs window. I thought that maybe the reason is in restarting my laptop or the Net Flex is disabled in Open systems, but everything was fine except the Maya. I uninstalled the version that I had and installed the new one. Still the same problem.
The output window says:
"Initialized VP2.0 renderer {
Version : 2016.11.53.12. Feature Level 5.
Adapter : GeForce GTX 960M/PCIe/SSE2
Vendor ID: 4318. Device ID : 6427
Driver : .
API : OpenGL V.4.6.
Max texture size : 16384 * 16384.
Max tex coords : 32
Shader versions supported (Vertex: 5, Geometry: 5, Pixel 5).
Shader compiler profile : (Best card profile)
Active stereo support available : 0
GPU Memory Limit : 2048 MB.
CPU Memory Limit: 15435.2 MB.
MultiDraw consolidation: enabled
OpenCL evaluator is attempting to initialize OpenCL.
OpenCL initialization has been disabled by user
00:00:00 691MB WARNING | [mtoa] [<built-in>] [node aov_write_vector] Assigning temporary node id 1138176 to associated Maya type name aiAovWriteVector."
patrick.schock
Autodesk Support
Autodesk Support
Hello @21915791,
thanks for sending this post. I would recommend to update the driver of your GeForce GTX 960M graphic card and test if Maya will start. It would also recommend to reset the Maya user preferences to start with new preferences: How to reset the Maya Preferences to Default.
Please update also the Arnold for Maya plugin: How to download Arnold updates
Looking forward to your reply if it helped!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
