Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't import same FBX multiple times?
4 REPLIES 4
linnjia
5943 Views, 4 Replies
I have spend several hours on this. I know this might be a stupid question, but please help...
I want to put multiple people in the scene. So I'm trying to import people.fbx into the scene. It succeed at the first time. I grouped the meshes and skeleton and name it in name people1. But I can't import the same people.fbx again. Is there any way to import one .fbx into the scene for multiple times?
Thanks very much!
4 REPLIES 4
Anifex09
in reply to: linnjia
This is an easy fix. When you import an FBX file you are given some option on how you want to import the date. The default setting will just update the scene. You need to set it to ADD this will rename the components and add it to the scene.
rmon61
in reply to: Anifex09
Thanks Brother
how do I have those objects replaced by the incoming fbx?
shatehen
https://knowledge.autodesk.com/support/maya/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Maya-Dat... Its here, you neeed to change in impornt in FBX mode ,,add + update" for ,,add" only
