Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can't get constraints to show in the outliner...
3 REPLIES 3
kanga007
4929 Views, 3 Replies
Maya 2014
How do I get constraints to show in the outliner. The headings in the ref (F1) are not to be found above the outliner only somewhere hidden in the attributes editor, which doesnt help the constraints to display where I can use them.
Any advice welcome.
Cheers
3 REPLIES 3
Anifex09
in reply to: kanga007
This is most likely due to the outliner filters. They do not include Constraints as a filter option. So even if you have everything checked in the show - Objects - Pulldown it will not display the constraints. Just go to the Show Pulldown - Objects - Clear All this should solve your problem.
kanga007
in reply to: Anifex09
Worked perfectly!
In Maya 2014 its 'Clear Below' and works fine.
Cheers and thanks a million.
Adi.koriat
hey there !
there is a way to reveal  with component i did the constrain?
for exaple :
i have a Hip ctrl and id like to know with joint it controling
