Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Can not find prefs folder. [MacOS Catalina]
5 REPLIES 5
NN_SS
1093 Views, 5 Replies
Issue:
Maya version is 2020 and 2019.
Changing the Maya2020(2019) folder name did not change the settings.
Where did MacOS Catalina create that folder?
Trouble exactly like this URL occurred
https://knowledge.autodesk.com/ja/support/maya-lt/troubleshooting/caas/sfdcarticles/sfdcarticles/JPN...
OS:
Mac OS Catalina 10.15.3
Kind regards,
5 REPLIES 5
warnold1
in reply to: NN_SS
From the provided link, the Mac preferences can be found as below
note that by default Apple “hides” the ~/Library
if one can’t find/see the path, may be easier to use a Terminal window
Resetting preferences on Mac:
  1. In the Finder, click the Go menu and then click "Go to folder..."
    /Users/<username>/Library/Preferences/Autodesk/Maya/<version>/
Note: If copy/pasting the path from above, edit USERNAME (custom username for the computer/account) and VERSION (version of the software in use) as appropriate​​
Wayne Arnold
Developer
NN_SS
in reply to: warnold1
Thank you.
I'm glad any advice.
I checked library folder.
But there was no prefs folder.
No Autodesk folder in library folder.
I found two libraries, but neither of them.
If anyone knows the solution, please advise.
Macintosh HD/library/Preferences/
Macintosh HD/User/Sistem/Library/Preferences/
Parmenides
in reply to: NN_SS
The user library is hidden by default.  If you go to the Finder/Go and hold the option key down, this will reveal the user library. See attached. There you will find the Preferences/Autodesk folder.
Hello, I'm having the same issue. Did you find any solution to your problem?
/Users/<USER>/Library/Preferences/Autodesk/maya/2020/prefs
