Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Bump map for shadow?
2 REPLIES 2
kenne150
501 Views, 2 Replies
I'm integrating some models into a video. The models will be sitting on concrete. The shadows cast by the people in the video are cast onto concrete, making the edges of the shadow a little textured, wavy and uneven as it follows the concrete.
The shadow of my models are smooth, so I'm trying to figure out a way to make their lines a little textured and uneven like those in the video. I'm not sure how to go about this. Is it possible to put something like a bump map on the shadow matte? I don't see the option, and I'm not sure that it would even work, but it was a thought. I've messed around with the Shadow Matte a lighting attributes quite a bit, but nothing is really making the effect I'm looking for. I don't really want to have to do anything in post processing, so I'd appreciate any help and suggestions on how I might achieve this in Maya.... I'm currently using Maya 2018. Thank You. 🙂
2 REPLIES 2
mspeer
in reply to: kenne150
Hi!
Bump mapping will not work, you can use a displacement map but you need these details as real geometry at render time.
kenne150
in reply to: mspeer
Thanks. I finally just put a texture deformer on the Plane that I had the Shadow Matte on. It's helped some. Good enough for what I need.
