Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Bug with Image Planes and "Use Depth Map" with Image Sequences
0 REPLIES 0
Message 1 of 1
nickkUMJHK
162 Views, 0 Replies
We are noticing a bug with the ImagePlane node in Maya-2020.4. If we use an .iff image sequence along with "Use Depth Map", it seems like the depth data is only read from the first frame rather than the image that is currently being displayed in the image plane.
I am testing with Viewport 2.0.
This works as expected in Maya-2019 (the depth map changes along with the image). I can provide example files if you need them, but they should also be easy to generate.
Has anyone else seen this bug? Any workarounds or patches to address the issue?
Thank you!
Labels (3)
0 REPLIES 0
