Announcements
Bug for importing image plane.
jjbbqq
jjbbqq
Seems like Maya didn't handle file name with dot in it well. If I have these files, and use View > Image Plane > Import Image to import CameraMatchingReference.0003.jpg, the image CameraMatchingReference.0001.jpg will displayed instead at first. When you click the image in the viewport, it will change to the correct CameraMatchingReference.0003.jpg.
You can see this in the video:
jjbbqq
It seems like the image naming let Maya treats it as image sequence.
Image plane syntax
When you import an image as an image plane, the syntax must be as follows:
  • name.#
  • name.#.ext
