Bug arnold maya 2017
Message 1 of 11
Hey ,
I have a problem with arnold and maya 2017 student version
I Have black screen in my viewport and on rendering view.
I try editing the viewport settings .
Pls anyone can help?
GPU 1070
CPU i7-6700k
Windows 10
Replies (10)
Message 2 of 11
Stephen.Blair
Hi
Is there anything in that scene? Any lights?
Let's see the Arnold log: https://www.google.com/search?q=arnold+log
// Stephen Blair
// Arnold Renderer Support
Message 3 of 11
Hi ,
Here it's the same problem with a scene with light
Message 4 of 11
Stephen.Blair
Sorry, screenshots don't help. An Arnold log might.
// Stephen Blair
Message 5 of 11
It's maya log from currently projet.
Message 6 of 11
Stephen.Blair
Hi
Thanks. That's only a partial log, so I can't tell for sure what's happening.
To get a full log, in the Arnold Render View, click View > Log > Full
Your mesh light is not set up right:
00:01:05 1222MB WARNING | group2|light_pSphere1|light_pSphere1Shape : no polymesh linked to light
Did you stop the Arnold Render View part way through? There's no errors, but the render stopped at 50% of the last progressive step.
// Stephen Blair
Message 7 of 11
Thanks. No i didn't stop rendering , my problem is i can't see all arnold renderview is partially black . i don't know how fix it
full log :
Message 8 of 11
Stephen.Blair
Hi
I was wrong. Screenshots do help in this case.
You are zoomed out in both your screenshots. Try viewing at real size (Window > Real Size)
// Stephen Blair
Message 9 of 11
hum I tried but it doesn't work
Message 10 of 11
Stephen.Blair
Doesn't work how?
If you batch render, is the image good? (you'll have a watermark, but except for that, does it work?)
If you use the Maya Render View, does that work?
If you change the Render Type (System tab) to Export ASS and Kick, does that work? (you'll have a watermark, but except for that, does it work?)
// Stephen Blair
Message 11 of 11
If i render my scene it's works , my arnold render view too but the problem is the just black screen .
Maya works with direct X and make a black screen too in my viewport if i start maya with open gl core profile or legacy .
Maybe there is a relatioships between the two problems?
