Broken/Corrupted/Damaged Maya Ascii File
Message 1 of 1
My .ma (Maya Ascii) File dont open in Maya. If i try to open it it appears the following Error Message:
[Errors have occured while reading this scene that may result in data loss. Please check the Scirpt Editor for details]
I have only one file of my Maya Sene/Model but i found 10 old autosave files and over a douzen files in /c/user/appdata/local/temp which maybe includes the same Scene/Model.
But everywhere the same issue 😞
The Scene was created with Maya 2015 and i tried to open it with Maya 2015, Maya 2013 and import to Maya 2015/2013 and to ZBrush 4R6. But the Error is still alive 😞
What can i do? How can this happen? Over 30 Maya Ascii Files of the Scene and Yesterday everything works perfect. i could open an save it a lot of times, but today nothing works 😠
i really appreciatet about help
best regards,
I30R6
Here is the Script Editor Entry:
file -f -o "C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma";
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 5: Unknown Maya file version: 2015. //
// Warning: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 5607: Unrecognized node type 'polyBevel2'; preserving node information during this session. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 7195: The polySmoothFace 'polySmoothFace1' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 7195: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 7438: The polySmoothFace 'polySmoothFace2' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 7438: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10177: The polySmoothFace 'polySmoothFace3' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10177: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10185: The polySmoothFace 'polySmoothFace4' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10185: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10471: The polySmoothFace 'polySmoothFace5' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10471: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10479: The polySmoothFace 'polySmoothFace6' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10479: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10514: The polySmoothFace 'polySmoothFace7' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10514: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10533: The polySmoothFace 'polySmoothFace8' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10533: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10541: The polySmoothFace 'polySmoothFace9' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10541: setAttr: No object matches name: .sdt //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10628: The polySmoothFace 'polySmoothFace10' has no '.sdt' attribute. //
// Error: file: C:/Users/David/Desktop/Skybox -Informatic Tree-/Skybox.ma line 10628: setAttr: No object matches name: .sdt //
// File read in 0 seconds.
// Error: line 117: Invalid flag '-particleInstancers' //
// Warning: line 1: Can't perform polyPlanarProj1 on selection //
// Warning: line 1: Can't perform polyPlanarProj2 on selection //
// Warning: line 1: Can't perform polyPlanarProj3 on selection //
// Warning: line 1: Can't perform polyPlanarProj4 on selection //
// Warning: line 1: Can't perform polyPlanarProj5 on selection //
// Warning: line 1: Can't perform polyCylProj1 on selection //
// Warning: line 1: Can't perform polyMapDel1 on selection //
// Warning: line 1: Can't perform polyPlanarProj6 on selection //
// Warning: line 1: Can't perform polySplitRing10 on selection //
// Warning: line 1: Can't perform polySplitRing11 on selection //
// Warning: line 1: Can't perform polySplitRing12 on selection //
// Warning: line 1: Can't perform polySplitRing13 on selection //
// Warning: line 1: Can't perform polySplitRing14 on selection //
// Warning: line 1: Can't perform polySplitRing15 on selection //
// Warning: line 1: Can't perform polyDelEdge9 on selection //
// Warning: line 1: Can't perform polySplitRing18 on selection //
// Warning: line 1: Can't perform polySplitRing19 on selection //
// Warning: line 1: Can't perform polySplitRing20 on selection //
// Warning: line 1: Can't perform polySplitRing21 on selection //
// Warning: line 1: Can't perform polySplitRing22 on selection //
// Warning: line 1: Can't perform polySplitRing23 on selection //
// Warning: line 1: Can't perform polySplitRing24 on selection //
// Warning: line 1: Can't perform polySplitRing25 on selection //
// Warning: line 1: Can't perform polySplitRing26 on selection //
// Warning: line 1: Can't perform polySplitRing27 on selection //
// Warning: line 1: Can't perform polySplitRing28 on selection //
// Warning: line 1: Can't perform polySplitRing29 on selection //
// Warning: line 1: Errors have occurred while reading this scene that may result in data loss.
Please check the Script Editor for details. //
// Error: line 1: Error reading file. //
commandPort -securityWarning -name commandportDefault;
// AbcImport v1.0 using Alembic 1.0.4 (built Jan 16 2012 14:31:58)
// mental ray for Maya 2013
// Mental ray for Maya: using startup file C:/Program Files (x86)/Autodesk/Maya2013/mentalray//maya.rayrc.
// mental ray for Maya: setup
// mental ray for Maya: initialize
// mental ray for Maya: register extensions
// mental ray Node Factory: loaded
// mental ray for Maya: successfully registered
// mental ray for Maya: loading startup file: C:/Program Files (x86)/Autodesk/Maya2013/mentalray//maya.rayrc
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/abcimport.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/abcimport.dll
// generating Maya nodes...
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/AdskShaderSDKWrappers.mi
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/architectural.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/architectural.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/base.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/base.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/builtin_bsdf.mi
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/contour.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/contour.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/paint.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/paint.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/physics.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/physics.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/production.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/production.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/ptex.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/ptex.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/subsurface.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/subsurface.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/surfaceSampler.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/surfaceSampler.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/userdata.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/userdata.dll
// parsing C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/include/useribl.mi
// loading C:/Program Files (x86)/Autodesk/Maya2013/mentalray/shaders/useribl.dll
// AbcExport v1.0 using Alembic 1.0.4 (built Jan 16 2012 14:31:58)
updateRendererUI;
Replies (0)
