Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Boss ocean - light not displacing properly
8 REPLIES 8
Message 1 of 9
732 Views, 8 Replies
I have an object emerging from beneath the ocean. The line where the object cuts through the surface is completely flat / straight.  I want this boarder to obey the same displacement the as assigned to the ocean shader. Where can I assign displacement to make this happen?
8 REPLIES 8
Message 2 of 9
sean.heasley
Hi @Anonymous
Have you set up collisions properly? There's a lot of good tutorials on this that may help you.
Also, what kind of light are you using and what are you rendering the scene with?
Message 3 of 9
in reply to: sean.heasley
I used arnold skydome and arnold renderer. Also forgot to mention I used the Boss ocean cache files as a displacement map, projected on a low poly plane to keep render times low. That's not the actual Boss ocean in the render..not sure if that was clear. I'm pretty sure I set up the colider properly as I can see the wake it generated. I also used the wake cache files as a bump map on the low poly place as wellLine.jpg
Message 4 of 9
sean.heasley
Hi @Anonymous
Ah thanks for attaching that second image! It's a bit easier to see what's happening and possibly going wrong.
For one, you might want to add a bit more thickness to your model and/or change how it's animated. The fin is so thin and depending on how it's breaking the surface the result might not be that obvious.
If that doesn't change anything, I'd recommend following along with this Boss tutorial series we have!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 5 of 9
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 6 of 9
Appreciate the follow up, thanks!
I've followed the tutorial very closely and still encounter the same issue. It seems some aspect of the flat low poly plane - maybe its transparency or its refraction's is still visible in the render. This is most noticeable against objects that intersect the plane. Attached is a higher contrast to further clarify Boss2.png
Message 7 of 9
mspeer
Hi!
Please upload a scene-file.
Message 8 of 9
sean.heasley
in reply to: mspeer
Hi @Anonymous
Hmmm ok.
Like @mspeer said, when you get a chance can you please zip and attach the scene file here or via dropbox/google drive or another file sharing program so we can take a look at it?
Message 9 of 9
sean.heasley
Hi @Anonymous
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Technology Administrators
