Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
blinn texture invisible in renderview
2 REPLIES 2
21robertpeterdaly
139 Views, 2 Replies
Hello there,
First time poster. I'm trying to do my student degree film here and using a model called Twigs from the Agora Community website (https://agora.community/content/twigs). Previously all textures were appearing in the renderview with no issue, but now the character's skin is not showing up in the render. I have not made any changes to the original model in any way, I have even deleted and re-downloaded the model and the problem still persists. Has anyone experienced this issue before and if so can they help?
I'm using Maya 2022 on a MacBookPro with OS 10.13.06 if that is of any relevance...
Thanks so much to anyone who can help,
Rob.
2 REPLIES 2
Hi @21robertpeterdaly
I had the exact same issue, and I've just spent the last 30 minutes trying to figure it out. I have found a solution! It worked for me anyway, hopefully, it does for you.
In the outliner I expanded the 'Twigs' group, then the 'model_grp', then the 'model_hi_grp', and finally the 'cowBoy_grp'. Scroll all the way down and select the skin mesh, it's called 'cowBoy_geo'. Then in the attribute editor, click the 'cowBoy_geoshape' tab. Once in there, under render stats, just tick the 'Primary Visibility' box.
That's what worked for me so I just thought I'd let you know.
Lemme know if that helps, if it doesn't work maybe I missed something, just tell me.
Amazing, that worked perfectly! Why would that be turned off? Anyway, you're both a life and a degree saver, thanks so much for the response.
Rob.
