Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Blend shape driving joint rotation?
4 REPLIES 4
everlite1knight
545 Views, 4 Replies
Hi, Is it possible to use a blend shape to drive the rotation of a joint within a 45 degree limit? When a blend shape increases from 0-100 percent; this will rotate a joint on the X axis in a limited range between 0-45 degrees.
And equally is it possible to do the reverse, have a joint rotation drive a blend shape?
Thank you
David
4 REPLIES 4
mspeer
in reply to: everlite1knight
Hi!
Please check the Maya online help for "Set Drive Key".
everlite1knight
in reply to: mspeer
Ok, will look into Set Drive Key. Thank you for the direction!
David
mspeer
Hi!
I missed one character, it's "Set Driven Key".
everlite1knight
in reply to: mspeer
Its a perfect response. I resolved the mystery based on searching for that term. Very simple in practice, but if you dont know about it, very frustrating lol
Thank you
David
