Big shelf separators
Hello guys,
Yesterday my Maya crashed many times. This affected some changes to my UI.
One of them is relating to the shelves: The separators are now absurdly big. (I assume it is the size of the usual icons.)
I like the layout with the text under the icons, so I did this before. But now the shelves need unnecessary much space.
Can I reset this somewhere in the settings?
I hope you can give me any hint here, thanks in advance
I just noticed, the bug had only affected the Poly Modeling Shelf. I was able to repair it with a lot of click-work:
Insert new separators at the end of the shelf (they worked as designated) > shift back to their position step by step > delete the old separators
I don't know why there isn't any option to simply adjust the separators' space, but I am fine with them now.
klaja
Observer
Observer
I hoped this will change in new version but its 3rd version of Maya, 2024, where this problem persist. Maybe its older problem, before I didn't used Maya. I have just icons, but separators from time to time get bigger only on Poly Modeling Shelf. I manually repair them and after some time these are screwed again. Not a huge problem but it is annoying as it moves down custom buttons I placed on the shelf for convenience. Again, the only way to fix it I found is to replace big separators with new ones. It would be acceptable solution if I wasn't forced to do that couple times a month because it is at random changing that separators over and over and over again. If anybody has any solution I would love to hear it.
corbata
How do you create a new separator in the shelf? I can move existing separators in the shelf but I don't see any options for adding a new one.
klaja
Observer
Observer
You can make it with script or there is an option in Bonus Tools/create/separator on shelf.
corbata
That's awesome! Thanks!!
absoluteKelvin
its kinda annoying not knowing  what trigger this issue with the separator spacing. Im currently trying to fix it for my custom toolbox i have written.
https://www.artstation.com/kelvintam
